2 Questions:
1 Do you have a pic of where on the block you tapped your Ground? I tried following the factory ground and
2. Instead of making the run from the alt to batt, could you not just remove that fusable link of 12ga wire in your 2nd picture and go into that distro block? There is a nice chunk of metal inside that red housing with some nice lugs to tap into. The reason I ask, I still have the factory batt and side post real estate is at a premium, if you know what I mean.
