Old 04-21-2006, 12:11 PM   #31
LiLHooT
LiLHooT's Avatar
Member ID: 12442
Re: NBS Big 3 upgrade
Originally Posted by 94FlamdS10Blazr
yes and you eliminate a huge safety feature that might save your truck from burning to the ground one day
Ok, so you are saying "Don't" do this mod. Just do the grounds
I believe the point of this is to increase current flow from ground back to alt (I studied hole flow). By jumping the link from the alt to the batt...you ellimnate the fusable link to the red junction box.
My question is, if you are going to do this, why not just run an 8" piece from the alt to the red junction box...
It was stated earlier that if you did that the minimum ga wire would be 6Ga. But if you run this direct to the battery as stated, you eliminate everything. You have 1/0 ga direct wired to the alt. Oh well...
05 Crew Z71
70 fleet side
When it quits being fun...quit doing it
