Old 05-27-2006, 07:27 AM   #29
Kruznlow69
Wuuuazuuup!!!
Kruznlow69's Avatar
Member ID: 326
Re: The York Thread.
Originally Posted by tmack
just wondering if this kit is worth it or would it be cheaper to buy everything seperate just seems like it makes everything a little simpler is there anything its missing that i would need to get thanks http://www.suicidedoors.com/96-98Che...nVortecV8.php#
i havnt ever installed a kit but it would be nice not to have to sit and spend a spend a day figuring out parts, running around getting parts, and fabbing up brackets.. then testing everything... i would go with a litle higher pressure though.. im running my custom york 210 setup at 200psi and its good as i know several others do as well. would need a higher pressure BOV, i got a 250 psi one.. Larry at innovative carries them.
Originally Posted by ********
can you safly run the square D pressure switch(as pictured above) with the edc kit from ssd.com at 200PSI.
i havnt ever used one with the kit so i really dont know but i think are are guys on here doin it.. try to contact the actual maker of the kit and ask???
i will be selling my square D switch i got from suicide cause it doesnt have the unloader. i dont think the EDC "kits" use them. i just want to do it..
REBUILD THREAD Wreck Thread My StreetSource
"Lifes all bout making mistakes, It's how you learn from them that counts"
