Old 06-05-2006, 11:02 PM   #50
LiLHooT
LiLHooT's Avatar
Re: NBS Big 3 upgrade
Originally Posted by BlameCanada
Your assumption is incorrect.
Well thanks for the ohms law explanation... My assumption was based on this as where the RVC is more prevelant in newer vehicles.
Document ID# 1745519
2006 Chevrolet Chevy C Silverado - 2WD
Subject: Volt Gauge Fluctuation - keywords cluster electrical excessive fluctuation gage generator intermittent IPC operation volt voltage voltmeter wire #PIT3331A - (12/16/2005)
Models: 2005-2006 Cadillac Escalade Models
2005-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2005-2006 GMC Sierra, Yukon Models
with RVC
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that their voltmeter is fluctuating between 12 and 14 volts on their full size pickup / utility vehicle.
Recommendation/Instructions:
Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The alternator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation and NO repairs should be attempted.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
05 Crew Z71
70 fleet side
When it quits being fun...quit doing it
LiLHooT is offline   Reply With Quote
