Old 08-03-2006, 10:46 AM   #66
x6369x
eBay-aholic
x6369x's Avatar
Re: NBS Big 3 upgrade
Originally Posted by ltn
Ok now what is that thing that i need if i have a side connector batter with no top one and can i get those at like autozone.
Originally Posted by x6369x
Yes, you just need to replace the OEM battery terminal lugs with GM adapters like this from Stinger:
Also all off the grounds, do they have old ones of where they used to be and if so do i just use the same grounds for the new wires.
You just need to add a ground from the block to the firewall (if there is an existing one), and add another ground from the battery to the chassis.
x6369x is offline   Reply With Quote
