Old 09-07-2006, 09:29 PM   #1
ImpalaGuy
"Wow that's.. uh.. loud"
383 buildup started, check out the pics!
Well guys, after 2 years of ownership I've finally got my 383 underway. The plan is a bang-for-the-buck street 383 to liven-up the truck. Right now my tired 350 is probably putting out 150-160HP, and I'm hoping for 350-400 HP out of the 383. Here's the plan:
  • 383cid short block ($1300)
  • Ported vortec heads (ebay: $700)
  • 50mm TBI w/80lb injectors, injector spacer and AFPR ($400)
  • Edelbrock Performer RPM vortec intake w/adapter ($200)
  • Roller cam from a ZZ4 crate motor (208/221@0.050") ($100)
  • Roller lifters, pushrods, retainers ($0, had 'em from an LT1 buildup)
  • Afterburner headers ($285)
  • 8mm plug wires and Procomp distributor ($125)
  • Gaskets: $100
That totals $3200. If history is any indication it will probably be ~$3500 by the time it's done. Here's some pics of what's happening so far...
Here's the freshly assembled 383 short block. I had the block but the pistons and crank are new..
Check out the 4 bolt mains on the bottom. The rods are LT1 ones that I already had...
Vortec heads. Fresh valve job and new springs...
Nice big 2.02" intake and 1.60" exhaust valves. Hard to stuff any bigger ones in there :)
There's power in a good port job. Check out the smooth intake ports in the vortec heads...
And a quick shot of the 50mm throttle body. Overpriced, IMHO, but I need to fuel this beast...
I'll keep you guys posted as the progress continues!
Ron
1996 Impala SS: 396 LT1, T56 six speed
1966 Impala SS convertible: 396 carb, four-on-the-floor.
1995 K1500: 383 TBI, vortec heads, Comp 502 cam, 50mm TB. AND STILL TRYING TO TUNE THIS @#$%^& THING!
ImpalaGuy is offline   Reply With Quote
