I'm not sure I understand....would you use the sum of the two amplifier channels or one channel to determine the amp output? Do you use the total speaker load if using more than one speaker or do you use the impedance of an individual speaker? The overall process makes sense, I just want to be sure I'm using correct data....garbage in, garbage out...
