Old 10-03-2006, 07:07 PM   #9
ImpalaGuy
"Wow that's.. uh.. loud"
Re: 383 TBI buildup, lots of pics!
Originally Posted by chevyz71man
Your not sposed to get that lube on the cam bearings... Although it is a synthetic lube it is still to gritty for them. Also being a roller cam, theres really no break in for the lifters. your going to chew those bearings up man..get the red crap for flat tappet cams off that roller cam.
The prelube is FOR the bearings. They're dry on startup and the cam would grind on them until oil got there. You're getting prelube confused with cam break-in period. Flat tappets need to be broke-in on the first startup and the prelube protects them until the lifters mate with the cam lobes. Roller cams don't need a break-in, but the prelube is still good protection.
I put prelube on all cam, crank and rod bearings, valve stem tips, rocker arm pivots, pushrod ends, etc. Basically anywhere there's metal-to-metal contact that the oil normally lubes. There's no "grit" in prelube. It's really just heavy weight oil. It washes out once the hot oil goes through there.
Ron
1996 Impala SS: 396 LT1, T56 six speed
1966 Impala SS convertible: 396 carb, four-on-the-floor.
1995 K1500: 383 TBI, vortec heads, Comp 502 cam, 50mm TB. AND STILL TRYING TO TUNE THIS @#$%^& THING!
ImpalaGuy is offline   Reply With Quote
