Thread: disc brake swap
Old 10-29-2006, 06:52 AM   #11
Low88
Drive and Enjoy.
Low88's Avatar
Re: disc brake swap
Originally Posted by cxpcman
nice ..got lot of questions ... any caddy will fit ? or theres a special model to look for ? .. the rotors you are using are the ones of the caddy?. they fit 15" wheels ? do you think is necessary to add a proportioning valve to make them work better ? how much for just the brackets ?
I think the calipers are from a 79-85 caddy seville. I got them because of the mechanical E-brake, I wanted an E-brake back this time around. you can use S-10 or other GM calipers if you dont care about the e-brake.
I am using modified impala SS rotors, I dont know if they fit 15" wheels, but I can tell ya in about an hour.
Not so sure on the proportioning valve quite yet, as my truck is in shambles, but im going to do what i have to, to make them work.
and the brackets were $10 each, and fit perfect... which is suprising for a speedway motors product.
hardest part of the swap was tearing in to the rear end to get the axleshafts out. it was super easy in hindsight, but it was my first time tearing into a rear end. Just remember that the pinion shaft holds two spider gears in, and the axlehsafts hold the others, and you will be alright.
Low88 is offline   Reply With Quote
