Thread: disc brake swap
Old 10-29-2006, 08:51 AM   #15
Low88
Drive and Enjoy.
Low88's Avatar
Re: disc brake swap
Lowgreen, this is the bracket i used http://www.speedwaymotors.com/xq/asp...qx/Product.htm... you drill two holes and bolt it to the flange. with impala SS rotors it works perfect. You do however, have to machine out the holes for the lugs on the impala rotors. the lug pattern is correct, but the holes need to be enlargened to the same size as the studs.
and btw everyone, 15's fit!... im pretty pumped, because now i can carry one of my 15" spares with me and be fine.
excuse the rust... caliper needs cleaning and its my 15" steelie... just to show clearance.
if there is enough interest, I can write a how-to, and take pics when i disassemble it again.
Low88 is offline   Reply With Quote
