Old 11-26-2006, 01:41 PM   #48
Blazer79
Member ID: 28748
Re: Chevy Lean **updated 9/19/06**
I own a 2001 1/2 ton 2WD, i went to the extent of changing the whole coil spring on the LF and it didn't make much of a difference. I also thought of another cause too, if you have a weak LR leaf spring, it would do the same thing. It would lift the RF higher than the LF. I corrected that by putting a set of air shocks on the rear, and pumping the LR more than the RR.
