Old 12-11-2006, 09:06 PM   #40
ImpalaGuy
"Wow that's.. uh.. loud"
Re: 383 TBI buildup, lots of pics!
Originally Posted by TrmBrainInjury
Bad news, I called Tom at Turbo City today to buy all of the upgraded TBI stufff I would need to run this motor and he said there's no way to upgrade even a big block TB to feed this motor and cam combo. Now I'm looking at the xtreme xfi stuff and it looks like it's going to take a while to afford this set up. Has anyone tried any other systems that work well and are emissions legal kits?
I bought the 50mm TBI from xtreme FI as well as 80 lb/hr injectors. As you found, it's not cheap. I thought of using a vortec stealthram also, but was leary of trying to get an LT1 throttle body to work. I don't know if it would be impossible, but I'm sure it would take dozens and dozens of tunes trying, and even then it might not work. So I bailed on the stealthram idea and stuck with the TBI.
The Edelbrock MPFI isn't that great for bigger displacement motors. I tuned a friend's truck with a 383 and that system and an even smaller cam and non-ported heads. I would read vacuum at WOT with the datamaster. The intake that comes with it has ports that are too small. They're basically the same as the Performer manifold, verses the Performer RPM that I went with.
Looks like I'll be installing her around 12/30. It was freakin' 18 degrees this past Saturday!
Ron
1996 Impala SS: 396 LT1, T56 six speed
1966 Impala SS convertible: 396 carb, four-on-the-floor.
1995 K1500: 383 TBI, vortec heads, Comp 502 cam, 50mm TB. AND STILL TRYING TO TUNE THIS @#$%^& THING!
ImpalaGuy is offline   Reply With Quote
