Originally Posted by prerunsilverado
well in the picture i have them just "set" in place so i could mock up arms and do some geometry but fiberglass is a bitch. they definatly dont fit anywhere close to as good as factory (duh) so you have to kinda shape and fit them to your truck. these are hannemanns 5" flair, and i needed every inch when i cycled the wheel into the fender.
please tell me you have a front end built and that your not going to run white brotastic sicky knar wide fenders and no front end.
HA HA no im not goin to run 5 inch flare ones... i just have a fab 7 inch with 15x10's so my tires stick out enough to run a three inch flare set ( trac increased about 3.5 per side i beliver with tires and spindles). I believe the hanneman set like that looks almost stock except for a 3 inch buldge around the whell well opening and they allow for a larger tire.. I honestly think they just look awesome and was just tossing around the idea of putting on a set when the summer gets here..
it would either be the haneman or the glass works unlimited set.. (both look different)
but deff not the 5 inch variaty your running lol
1989 1500 2wd 5.7 V8
7 inch fabtech lift
bilstein 5100 shocks, rancho steering stabilizer
33x12.50 BFG MT on 15x10 procomp extremes
Dual flowmaster 40's
AEM Brute Force air intake and TB spacer
