Originally Posted by roskey5205
If you are using an amplifier that has an RMS rating of more than your speaker(s) can handle/rated for
Are you talking speakers RMS or peak handling.
I always use the lower of the two. If the speakers are rated lower then the amps rating I use it. If the amp is rated lower, then I use the amps RMS power for the formula.
Always use RMS ratings when gain setting.
