Re: OBS Stock Floor Body-Drop how-to....lay that rocker
i went 2 3/4". Its getting shimmed up to about 2.5" which is perfect for laying rocker. I am running 255/45/17's and do not have to tub the firewall, and the heat is staying. If you are all about the big rollers, you will need to ditch the heat or relocate the box when you tub the firewall. You can lay rocker on a 255/35/20 tire though without tubbing the firewall. The firewall will need a little massage though.
