Old 02-21-2007, 04:21 PM   #47
slammins15
V8 S15 Jimmy member
slammins15's Avatar
Member ID: 24837
Re: Fix Those Wipers (Wiper Board Repair)
Originally Posted by 'radolover
If it carries over to more recent production, like up to '97s, then the same employee(s) may still be doing a bit of rough handling.
And if the same/similar problem is continuing for so long it would STRONGLY suggest that a bad batch of solder is not what's
going on.
Its not employess doing the soldering its done by robotics and the problem is caused by not soldering with enough heat so you end up with cold solder joints that crack eventually.
