Thread: Post Your Setup
Old 04-05-2007, 10:41 AM   #87
Silverad04
Silverad04's Avatar
Member ID: 57641
Re: Post Your Setup
Originally Posted by 50_89_04_chevy
2004
Chevy
Silverado
2wd
Stock
Stock, soon to be 16x8
Belltech 3/4 Drop, Nitro TwinTube Shocks
Stock Leafs, Kit comes with new poly bushing front and rear.
Stock Bumpers
Kit fits Like a glove.
I love the ride, but if any of you guys are from Tulsa, you know that some areas (Utica, for example) can be rough on a dropped ride.
THe only recomendation i have is that the kit had a torque spec for the new shackle brackets on the rear both driver and passenger side that said torque to 100lb/ft. Two of the bolts broke after barely 50lb/ft. So, i would say ratchet tight, I have checked the bolts at 10,100,1000 miles, and they have not budged, so its your call on that. Oh, and definitely remove the bed. You can do the install without, but it is sooooooooo much easier without the bed in the way.
Later,
Dave
Remove the bed for a shackle bolt? Thats nutz! All you gotta do is jack up the axle untill the leaf spring hole gets to the top of the bed. Then use the space in between the frame and the bed to put the bolt in.
2004 Silverado-RCSB-5.3-Pacesetter LT's-DynaTech Cats-X Pipe-Dual Bullets-Volant-LS1 E-Fans-PCM Tune
2005 Cavalier 5 speed-The 2.2 BEAST!!!
