Thread: 67-72 or 73-87
Old 08-17-2007, 11:27 PM   #28
gearheadperkins
4.3 ss
Re: 67-72 or 73-87
Originally Posted by bob308
i don't have any picks right now. but can tell you the clutch set up is different then a small block. the cross shaft the way the ball bolts on the block is all by itself. the ball on the frame bolts on back father then the small block.
the frame mounts for the motor are different too. but you can get by with the sb ones there. for exhaust you use on the right side chevelle. on the left impala. that is what the factory used.
power sterring is the same as 66-67 chevelle big block. same for the alt. set up. short water pump.
like this info
perkins
http://www.cardomain.com/ride/2551114
4.3 5sp 3.23's 57 chevy dash emblem on tailgate,flowmaster,10" bluethunder,chevy delete from the tailgate,265/70/17's
gearheadperkins is offline   Reply With Quote
