I know what you're saying about the vinyl & plastic, as far as feel goes, but unless you're going with the dark texture (like the radio bezel) the vinyl will look more OEM, quite simply because of the grain. Now with the SEM paints like you said above, I've seen them turn out with nearly identical texturing as the dark portion on the radio bezel.
