Originally Posted by thekl0wn
I know what you're saying about the vinyl & plastic, as far as feel goes, but unless you're going with the dark texture (like the radio bezel) the vinyl will look more OEM, quite simply because of the grain. Now with the SEM paints like you said above, I've seen them turn out with nearly identical texturing as the dark portion on the radio bezel.
I think that would look pretty good. Then it would match the other audio/video section of your dash and carry the theme down towards the cupholders which are the same.
2004 1500 Silverado Z-71 ECSB 5.3L 3" body lift, 305/55R20 Nitto Terragrapplers on 20x10 Helo's, and a few bolt-on's.
