Originally Posted by VenomousGT
i have a question....
i have a 91 c1500. When i rollmy window up or down it will get to certain parts and it will make a clicking noise (it sounds like the gears on the motor and the cog for the window mechanism are skipping). I took my motor assembly out completely today and looked over the gears to see if they looked stripped out. After an inspection I noticed the gears still looked great so on a whim I decided to put it all back together making sure everything was seated properly. I got it back perfect, crossed my fingers and hit the button ~~click click~~ same friggin noise! One thing I have noticed is that when the window stops and the clicking starts, I can grab the glass and wiggle the window a decent amount. There seems to me like there is too much play in the glass. I made sure the window was staying in the tracks and that the motor mechanism was installed into the window track properly.
does anyone have any suggestions??
i have the same exact problem on my 93 k1500 on my drivers side no idea what it is ive also pulled the door apart and tried seeing if i cud find anything but came up empty i'm assuming its the motor just doesn't make sense cause when i roll the window up i'll grab the top and pull it all the way up and get it completely closed with manual assistance and even with the window all the way up it still makes that grinding/clicking noise. probably gonna just go to a junkyard and pickup a new motor along with numerous other parts for many other projects. i'll keep you posted when i get this fixed.
