Old 11-19-2007, 01:27 AM   #5
99-2door
Heck Yes I Did!
99-2door's Avatar
Member ID: 28587
Re: Wiring for OBS denali seats into an OBS truck
Heated Seats Circuit Description
Heated Seat System
The heated seat system incorporates a heated seat switch, heated seat module, seat temperature sensor, heating elements in the seat cushion (front and rear) and heating elements in the seat back (front only). All the passengers seats (front and rear) have a seat belt switch that is used for an enable signal when the seat belt is buckled.
Front Heated Seat Description
The front Heated Seat Switches receive power, with the Ignition in the Run position, from the RR HVAC fuse in the I/P Fuse Block through CKT 341 (BRN). When the switch is placed in the LOW position, the ON signal is sent to the Heated Seat Module through CKT 1503 (PNK/BLK), and the HIGH/LOW Signal is sent through CKT 1505 (LT BLU/BLK) to the heated seat module. The low side of the Heated Seat Switch has approximately 275ohms of resistance, while the high side has approximately 310ohms of resistance. The Heated Seat Module receives battery voltage from the FRONT HEATED SEATS fuse, in the underhood fuse block, through CKT 1840 (ORN). With the heated seat switch on, battery voltage is sent from the module through CKT 1462 (LT BLU) to the Seat Cushion Element. Output is sent through CKT 1985 (PPL) to the Seat Back Element. Since the elements are connected in series, ground for both elements is provided through CKT 150 (BLK) to ground G202. The temperature sensors for the seats are located with the seat cushion element. The sensor monitors seat temperature and a varying resistance that is monitored at the Signal Enable, cavity E of the Heated Seat Module. The Heated Seat Module compares this signal to the HI/LO input to determine when to apply and shut off battery voltage to the heating elements. Temperature settings are maintained around:
37.5°C (98.5°F) for the LOW position.
42.5°C (107.5°F) for the HIGH position.
Both the Driver's and Passenger's, heated seats operate the same. However, the Passenger's seat needs seat belt buckled. When the seat belt is not buckled, the enable signal through CKT 182 (YEL) is grounded at the heated seat module and the system will not operate.
Well that explains the yellow wire.
2001 C3 6.0 AWD, 3/4 drop, Volant intake, flowmaster exhaust, 05 e-fans, tune....in progress
2003 Tahoe Z71 5.3L, Silverado clip
