Old 12-19-2007, 05:12 PM   #10
97whtgmclowrd
Re: Alignment question
they are called knock outs, On OBS ther located top of the frame rail where your uppercontrol arm bolts too. there pretty easy to do your self if you have the tools, they even make a tool for it. there are indention's in the metal where to cut out. sometime's you have to go further. to get caster and camber to spec's, just remember there has to be a 1/2 degree or more split between both sides of caster or you will have a pull.
97whtgmclowrd is offline   Reply With Quote
