Re: How to identify if your 73-87 was repaired by GM's fuel tank recall
and in a major side impact accident, the fuel tank is the least of your worries.
do you have links to GM's records stating that this is a severe problem? i'm calling BS on the K series truck's "lack of frame flex", because i have seen the part numbers, and the rails between a C truck and a K truck (of equal rating, C10/C20 to K10/K20, and C30 to K30) carry exactly the same part number. there are no extra crossmembers in a K truck to make the frame flex less.
i build and wreck these trucks on a regular basis, probably 15 or so a year, so i've got a little background in this area.
