Re: How to identify if your 73-87 was repaired by GM's fuel tank recall
i worked for the general for almost 3 years, behind a parts counter. i've probably read the 73-86 C/K catalog front to back 3 times. crossmember placement is VERY similar, as is crossmember design. i've studied alot on these trucks, to the point that i can walk a bare frame and tell you exactly where its going to bend and kink, and which directions the kink will go.
