Originally Posted by neevnav
Relay to battery, ground to ground, high to pole 85 or 86 (the on switch) low to 87. My lows don't flicker at all when I switch, highs just come on.
1 relay and harness to do this? You have DRL correct (being in Canada)?
Something doesn't make sense because pin #87 is switched so how can the LB stay on when switched to HB? Is there something else in your harness that you forgot or am I missing something here?
