Re: datalog/tuning options ?
The 0411 has 2x the processing speed of the Black Box PCM. It
also has Hi and Low octane spark tables so if the PCM senses knock it will start to bias the timing toward the lower table. It has Higher RPM capability and more tuning options.
Jeff
98 GMC RCSB 1/2 ton 2wd, 100% internally stock 305,Ramjet intake,42lb inj,Twin T-3 junkyard turbos,12200411 PCM. 4675lbs w/me in it. Best time on 5 passes 13.01@110
