Old 01-23-2008, 12:44 AM   #13
55chevyman
Like a rock
Member ID: 76873
Re: Couldnt hold out any longer
Originally Posted by FordeatinZ71
the chrome hood cover is available from LMC i think. if not, there are places out there that have it. as for DD, that means Daily Driver...but Daisy Duke can be in too...screw it...DD in the DD...being pounded by the DD...
and no, unless you convert to the newer front end you can't run the newer hood hinge setup...one of the crappers about running the older front end but if you keep the hood hinges lubed/clean they'll last quite a while. and when they start to wear out, just replace 'em. you can also get the low-tension hood springs for fiberglass hoods which put less wear on them, but i don't know if they would hold up a steel hood.
I just looked and couldnt find it in brothers or lmc...Im special and your not...haha..
Hey jax youare a if you think its funny when you lose a muffler
And i have plenty of power to get were i need to go..Comments like that is why people bash you
1975 3/4 c-20- Project finally in teardown stage
Loud pipes save lives
