Old 01-26-2008, 05:08 PM   #1
pfk
Premium Member #11
Supporting Member
pfk's Avatar
Member ID: 51816
I need help with programming ecm for new motor ,wont start anymore :(
Since may I have been trying to figure out a problem with bad logs, which turned out to be bad block, piston etc. The new engine is in place and hooked up only I can't get it to run anymore. My previous tune which was rough to begin with, barely let the engine run enough to make it around the block so I could get a starting point with editing the ve table. Oldred pointed out to me that I had overlooked the 2 bar map so I installed one, but now the engine doesnt run at all for me
I have no idea where to go from here. I figure that I will unhook the S/C enrichment system until I can get a running tune and then I will go back to it after everything is running ok.
Is anyone online that could give me a helping hand so that I can start tuning this thing? I am on both MSN and Yahoo messenger (both in my profile) I am about 15 feet away from the computer when I am sitting in the truck so I may not hear you instantly but I will check every few minutes.
Thanks in advance
1995 GMC K1500 Suburban, 385cc, .040" over stroker,Patriot heads ,1.6:1 roller rockers,224-236 113 lsa cam , Edelbrock Intake (performer RPM) Holley TBI Adapter, BBC TBI with vAFPR,Transgo Shift Kit, Dynomax cat back with Edelbrock ceramic TES Headers. Paxton SN93 s/c, electric fans 4.10 posi
