Old 01-26-2008, 07:23 PM   #6
pfk
Premium Member #11
Supporting Member
pfk's Avatar
Member ID: 51816
Re: I need help with programming ecm for new motor ,wont start anymore :(
OK, so I had an issue with a bent pin on the aldl connector which was screwing things up pretty good. When I fixed that and plugged the ecm back in with the 1 bar map, it started up perfect and runs fine (I know it'll still need tuning, but it sounds normal) I shut down and went back to the 2 bar map, it needed pedal to start and wouldn't idle. I am still having issues with my laptop so anytime I unplug one of my usb devices, it locks up, so I'm gonna go get my scanner to take the map reading instead.
I personally have not made any changes to the bin since it was done on the last engine (never made it that far yet)
1995 GMC K1500 Suburban, 385cc, .040" over stroker,Patriot heads ,1.6:1 roller rockers,224-236 113 lsa cam , Edelbrock Intake (performer RPM) Holley TBI Adapter, BBC TBI with vAFPR,Transgo Shift Kit, Dynomax cat back with Edelbrock ceramic TES Headers. Paxton SN93 s/c, electric fans 4.10 posi
