Originally Posted by FLAIRFAN
i used aftermarket keys my 03 1/2 ton and it barley raised it level about 1.5 inches. what does the ford key do compared to chevy aftermarket keys? on my 04 dodge 1500 i had it raised truck 2.5 plus cranked them up 2 inches in front then put 2 ich block in rear and it looked great. the chevy lift ws a wased of money for the small effect it had. im running 33 inch on 18's and hey cleared stock as well as now. im wanting to rub 35 tires.
The ford keys and the real chevy aftermarket keys are the same, they both are indexed differently to give more lift, here's a link to what the chevy 2" lift t-keys look like:
http://www.generalspringkc.com/index...193&parent=164
they're the same as the ford keys, except there isn't a cutout as you see with the ford keys. If you didn't get much lift for you new keys then you didn't have the bolts tightned enough, they need to be were they were when you took them out, if you still don't like the look, tighten them up a bit, you should get about 2-2.5" of lift with the ford keys, you can go 3" but then your causing undo stress on the suspention components
