Old 01-28-2008, 07:58 PM   #19
pfk
Premium Member #11
Supporting Member
pfk's Avatar
Member ID: 51816
Re: I need help with programming ecm for new motor ,wont start anymore :(
Originally Posted by 91chevZ71
I made this using a spreadsheet that I can't take credit for.
Compare the g/sec injector flow and cyl displacement to your stuff, might wanna change it and see what happens. Also, raise your injector offset by about 150 sec (the entire thing).
Thanks for posting the figures, I had it all calculated before but I forgot that I had done it at 15psi. off by 4 Grms/sec
Do you remember where you found the spreadsheet?
I take it you don't have a stand-alone display for the WB
-edit
take some timing out of the spark tables, possibly. I know the F/I setups run less timing than N/A ones do. still looks like a pretty healthy SA table, probably too much
No I don't have one, unfortunately I didn't see the use of having a stand alone display
I haven't even looked at the timing tables yet, not that far in my studies yet. I've been reading steady for months but have not had anything to experiment with so I haven't actually tried to apply anything that I may have learnt (sorry it took so long for the reply, I have 5 windows open,still reading )
1995 GMC K1500 Suburban, 385cc, .040" over stroker,Patriot heads ,1.6:1 roller rockers,224-236 113 lsa cam , Edelbrock Intake (performer RPM) Holley TBI Adapter, BBC TBI with vAFPR,Transgo Shift Kit, Dynomax cat back with Edelbrock ceramic TES Headers. Paxton SN93 s/c, electric fans 4.10 posi
