Old 01-28-2008, 08:42 PM   #20
getsideways
getsideways's Avatar
Member ID: 23891
Re: I need help with programming ecm for new motor ,wont start anymore :(
Originally Posted by pfk
I'm running 20psi on 90pph injectors so that may be why it appears leaner than your bin (it was actually running fairly rich according to BLMs)
your injector size and fuel psi has nothing to do with your ve table. the ve table is affected by cam,heads,manifold, etc...
what kind of wideband do you have? you need to get the wideband hooked up and in your logs.
95 1/2 ton short bed, 350 .02 over,world torquer s/r heads,edelbrock 3704 manifold, comp roller 210/214 (.510,.472) 114 sep, comp pro magnum roller rockers, 2" tbi, 65lbs injectors, walbro 190 pump, ceramic coated shortie headers. msd blaster coil.
