Old 02-06-2008, 06:39 PM   #1074
chriskg
Member ID: 81795
Originally Posted by stoltz23
Does any one else with cranked t bars or ford keys steering wheel point to 1:00? i just put in a new pitman arm and it seems worse than it was before. I am going to sell the truck and dont see how i can wiht the steering wheel like this. i did not see that there is any way to adjust the pitman arm but what about the tie rod ends can yopu make the passenger longer than the driverside to correct this?
Your supposed to get it realligned after you install the ford keys, you really can't align it yourself, unless you have the equipment, but have a professinal alignment shop do it for you. You just wasted money on the pitman arm too
