Old 02-09-2008, 10:54 PM   #246
sLOWrado01
ah nuts..I mean..ah nuts
sLOWrado01's Avatar
Member ID: 63087
i think a 4/3 drop would look funny, thats alotta rake. id just do a 2/3 drop n call it quits, 4 inches in the rear will bottom out without a notch (atleast my NBS did, OBS guys chime in), with a 3 u might be in trouble while haulin, but i cant tell you for sure there. the tires would be fine, you could probably run a pretty good sidewall with that mild drop.
sLOWrado
01' Black Silverado RCSB - 4/7 drop, Gunmetal OEM 17's, HD grille, Z71 fogs/valence, HID's, Little JL System, Smoked LED tails, and more...
95' Black Maxima VQ30 - Daily driver, 3" Tokico coil/shock drop, 24 mpg, leaks fluid like an old man...
