making a little more progress!
Here's the tanks with some cool drain valves. They have cables that will be routed to the rear you will just pull each cable to drain each tank!
here's the engine driven mounted
Here's how tight the pulley is to the ecm computer even after we moved it forward an inch.
Got a little plumbing done for the rear! We are gonna redo the inputs to the valves the lines are so short we will probably use a braided hose!
We are going to the world of wheels today so no more progress this weekend!
