Re: NBS Big 3 upgrade
The fusible link is the cable between the alternator and jump block. Putting a new cable between the jump block and the alt effectively eliminates the fusible link, so I removed it.
Yes, you can use a little longer ground strap. You can probably get away with using the same size, just longer. However, if you are going to do the Big 3 upgrade anyway, just make it bigger and longer!
NeonHomer
2004 Chevy Silverado 1500 Ext. Cab 5.3L/4spd
1994 Dodge Caravan 3.0L/4spd
2004 Harley-Davidson Road King Police FLHP/I
