Old 03-05-2008, 12:15 PM   #203
F4MOU$
Professional A$$hole
F4MOU$'s Avatar
Status: Online
Member ID: 84471
Re: Advice on bagging a truck
Air Ride Technologies all the way.
They have the Cool Ride (front):
Bolt on upper and lower control arms with the bags, shock is mounted outside like normal.
They have the Shockwave (front):
Which bolts on and replaces your coils and it can come with upper and lower control arms if asked for. You get better turning radius with the Shockwaves compaired to the Coolride because the shock is elminated and runs through the center of the Shockwave, preferred way to bag the front for bigger wheel and tire combos.
They have the AirBar (rear):
It is a Bolt on 4-Link, BOLT ON. No cutting or anything. , you dont lay frame, but it lowers your truck as much as possible without cutting unless you want to...
They have Parallel 4-links and Triangulated 4-links (rear):
Depending on how the gas tank is set up on your truck and where you need clearance and what not depends on which one you need, UNLESS the AirBar is not available for your application...
The have the S-10 Road Grater (rear):
The only kit on the market where you can bolt it on, with minor cutting, and lay frame with up to 28" tires. It comes with everything you need possible for the rear, built in c-notches, when i say everything, I mean E.V.E.R.Y.T.H.I.N.G.
And last but not least, Air Management:
They have the brand new AirPod which cuts down install 15-20 hrs.
Or the LevelPro which has preset ride heights and a few other Air Management Systems. Check out there website for more info.
www.ridetech.com
IF ANY ONE WANTS MORE INFORMATION ON ANYTHING FOR AIR RIDE TECHNOLOGIES, I SELL THIS AT WORK, AND FOR YOU WHO DO NOT KNOW, I WORK AT STYLIN TRUCKS. CALL ME FOR MORE INFO/PRICING AND I CAN HOOK YOU UP.
-DREW
'08 ECSB Z71 5.3L
Corsa RSC Sport, K&N CAI, Keystone Hood, Gaylords X2000,
Readylift, Edge Evolution
