Old 03-14-2008, 02:15 AM   #19
Gerald
Its just my style
Gerald's Avatar
Member ID: 34064
Re: Disable Headlight Twilight Feature (Auto On)
This is how to dissable them on the 03+.......
This mod will allow full control over your lighting using the manual switch on the dash.
This is copied from Diesel Place,
The wires for the Light Sensor go to the TBC. The "J" connector numbers are molded into the TBC under each connector. The "A/B" are molded on the ends of the connectors and just count wires to get to the right terminal.
Connector J3 terminal A4 = white wire for sensor
Connector J4 terminal B7 = black wire for sensor return
If you have auto climate control the black wire is shared with the left and right solar controls.
You could jump a small piece of wire between J3-A4 (white) and J4-B7 (black) to disable the Light Sensor.
If you have manual climate controls the black wire only goes to the Light Sensor so you could cut J3-A4 (white) and J4-B7 (black) and connect them together. Just be sure to connect the wire on the TBC end and not the ones going to the sensor.
No More Auto Headlights!
He used a little blue wire for the jumper. I found that leaving them pluged into the BCM, and using a small paper clip is alot easier.
Basics are...
Find the J3 plug, then the A4 (white) wire, jump a paper clip from this wire, over to the J4 plug, to the B7(black) wire.
I used heat shrink tubing over the paper clip to only expose 1/2" on both ends so its not to short out on anything.
Hope this will help you guys too!
'04, 10-12 3rd Coast, ford keys, heim steering, dual cv front driveline, FTS hoops and control arms, Bilstien 5125s, all spring out back with no blocks or shackles
