Re: Detailed pics of my intake gasket 99 tahoe!
This is the tech / technical section! If someone wants to nominate the post to be a sticky, then it will be moved then, otherwise, i believe I have posted this in the correct area for now.
As far as the distributor reinstall, since I spent alot of time noting the EXACT direction / angle / geometry of the distributor shaft, rotor, and cap, i was able to replace it all back in without one problem. In fact, the timing is closer to being perfect than it was before. THe engine runs VERY smoothly now.
Thanks for the comments!
'03 Chevy SCSB 4.3L W4M 93 tune CAI & Gibson Dual sport exhaust, Custom built LED tails
'99 Chevy K1500 4D Tahoe 5.7L 3/2 drop so far, Custom built LED tails.
