Old 03-25-2008, 09:45 AM   #9
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: 2500 6.5 turbo diesel problem
Sounds like classic PMD failure. But...
When it stalls is it like someone turned off the key? Do you lose your dash lights? What 'cutoff switch' did you replace?
If it is the PMD (most likely) you will want to buy it from Heath Diesel. You will pay more for it there than anywhere else but Heath's PMD isolator kit comes with a 7 year warranty.
Do not buy 'tested' or 'used but good' PMDs off of Ebay. Remember, 3 months ago YOUR PMD was 'used but good'.
1/4 Mile ET
16.722 @ 80.701 MPH
