Old 03-25-2008, 09:48 AM   #10
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: 2500 6.5 turbo diesel problem
Originally Posted by Dupontster
I had a 98 6.5 with the same symptoms...Hate to tell you this but an new injector pump fixed it....$$$$$$$ Yours may not be the same problem but like I said, it fixed mine...
That's because there was a new PMD on the new IP.
A new PMD instead of a whole new IP would have saved you a pile of $$$$$$
1/4 Mile ET
16.722 @ 80.701 MPH
