Re: Advice on bagging a truck
Hey, how's it goin'? As far as air tanks go, you can fit 3 5 gallon tanks under your bed behind the axle...Or you can run 1 12 gallon tank in your bed and put your fuel cell behind the axle under the bed...If you run your valves off of your tank, everything's in a central location - which is good for maintenance...Just a suggestion. For my gas tank, I used a gas tank and tank module from an '88 S10 Blazer and used the factory wiring...but I also have the 4.3... For your bags, I'd run Slam RE-7's up front, and RE-8's in the back. They're both 2600's, pretty tough, and offer better lift at a lower psi - which means a better ride. For airline, DOT stuff does the job nicely.
...Never falling victim to "The Norm"...
