Old 04-11-2008, 06:31 AM   #1112
LPG PWRD
Cowboy From Hell
LPG PWRD's Avatar
Status: Online
Member ID: 79183
Re: Ford Keys & Torsion Bar Cranking/Replacing TECH**
Originally Posted by Luke2kZ71
at this point, if u compare the 2 keys like so:
You will see that at the same position, the ford key's bolt dimple is lower, thus twisting the bar more with less cranking
That is on the first page and should explain it...
You can crank w/o the ford keys, but they will give you more if you did use them
DD: 2001 Silverado 1500 ECSB 5.3L
Project: '94 GMC ECSB - SAS resto project My stupid space
