Old 04-12-2008, 09:59 PM   #1
rob
Member ID: 6375
would you buy your truck over again?
simply put, knowing what you know now, about your duramax truck, if you had it to do over again, would you still have bought it? or would you stick with a gas truck, or go ford or dodge?
I'm torn between an '03-'06 ECSB 2500hd duramax/allison. or just buy a '96 or '97 ECSB 12valve/5spd cummins truck, and save a boat-load of money in the process.
is the duramax gonna be worth the extra money in the long run over the 12valve cummins?
the duramax would probably only see an edge juice box, exhaust, and intake as far as mods.
the cummins would see a fuel stop plate, exhaust, intake, and a capped-off wastegate vacuum line (hey, a friend layed down 305/800 with this combo in a '95 dodge)
is it worth it, or what?
'94 Z-71
heads/cam/intake/LT's/locker
'02 z-71
5.3/3.73/g80- 285's, no cats, single 3" aero chamber
'95 Formula
heads/cam/LT's/gear
'92 Civic
4-door 5-speed,35mpg
Tuned By:
Bluecat
KYHORSEPOWER.COM
