Old 04-14-2008, 07:13 PM   #6
TLL
TLL's Avatar
Member ID: 73169
Re: this Intake manifold possibile?
Originally Posted by paw2000
Thanks for the info, I read so many different problems and its hard to find answers. Which throttle body did you use? I looked thru the site and most of the rides were the older TPI cars. I have a complete 95 LT1 engine if I need to borrow parts from like the trottle body. I'm pulling the vortec motor soon as I have a coolant leak and figure nows the time to upgrade.
I am using an older Accel 1000cfm twin 58mm throttle body on mine but the stealth ram accepts any TPI ot LT1 throttle body. The LT1 is a good way to go with a conversion from a stock vortec set up because the TPS and IAC sensors will plug right in to the vortec harness and it uses the same style throttle cable too.
2000 Tahoe Limited-Powerdyne,Comp Cams, MSD, KenneBell, OBX, FlowMasters, TransGo, Multi-Tec IIs set @ 85 psi, Allen Nelson tuned, BellTech(3/3 drop), Hotchkis, Bilstein, 3.73 posi, Ported MAF & throttle body, e-fans, Cross drilled rotors w/oversized calipers. www.cardomain.com/ride/3047813
