Re: this Intake manifold possibile?
My stealth ram is going on my supercharged Tahoe Limited which has a 4.11 rear gear so low end is not really much concern to me. As far as what you need to buy the intake is $360 and if you go with the matching fuel rail/regulator kit it is another $180. I'm using a fabricated rail with an external adjustable regulator. The injectors vary in price by what you need. I went with a used set of LS1 injectors which are rated at 28.8lbs. They cost me $50 from a guy on thirdrdgen.com. I had the throttle body from a TPI unit I bought on ebay for $75 and sold for $150 without the throttle body. There are no brackets to buy. I have about $600 total in mine with the new injector wire pigtails and I feel the performance is well worth the cost.
2000 Tahoe Limited-Powerdyne,Comp Cams, MSD, KenneBell, OBX, FlowMasters, TransGo, Multi-Tec IIs set @ 85 psi, Allen Nelson tuned, BellTech(3/3 drop), Hotchkis, Bilstein, 3.73 posi, Ported MAF & throttle body, e-fans, Cross drilled rotors w/oversized calipers. www.cardomain.com/ride/3047813
