Old 04-16-2008, 03:41 PM   #35
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
Re: Started working on my girl
Originally Posted by 1974ChevymediC
and these mods would leave plenty of spline for the driveshaft when stretched? also, is this method for converting to longbed or only stretching the wheelbase? i would really love to have a long bed and would definitely consider this. do u have any pics or threads of this being done grease?
no, there wont be plenty of spline on the driveshaft. one of my buddies pulled his apart with 4" spring and modified shackle angle. you'll likely have to upgrade the ujoint at the axle, and the CV joint to compensate for the added suspension travel that you'll also see with this swap. you'll probably be able to avoid upgrading the joints by adjusting bump stops and adding limiting straps. you could get by with just going easy on it and not stretching the suspension out, but that's another of the advantages to the swap.
no, this is just for stretching wheelbase. check out www.coloradok5.com or www.pirate4x4.com, there are tons of threads on it.
1977 Chevy K20 - 350/350/203 10/14FF
1980 GMC K2500 - 350/465/205 10/14FF
1992 Chevy C1500 SWB - 5.7/4L60/14SF - totaled 5/9/08
1993 Chevy C2500 - 350/80E/241 10/14FF
1994 Chevy K1500 - 350/60E/241 IFS/G80 10 bolt
