Importance of a proper tune.
Just want to show you'll how important a proper tune can be, especially when working with a OBDI vehicle running speed density. This is a TPI Vortec 305 built up some, but none the less, I picked up over 30 RWHP from fine tweaking on the dyno. I started out at 322 RWHP @ 4,700 from tuning without the dyno. My biggest power gain surprisingly was changing the WOT air/fuel ratio from the mid 12 down to 11.6:1. E10 does some weird things to the Air Fuel Ratio and engine wants. WOT TCC lockup was worth 9 HP, but I lost 8 ft/lbs in the process. Messing with the timing resulted in power loss, so I left it the way I had it.
1983 G20 Conversion Van, 383 TPI, 10.5:1 compression, Custom Reed Roller cam, Ported 906 Vortecs, Doug Thorley Tri-Y headers, dual 2 1/2" exhaust, 4L60E, 3.08 gears. 7427 PCM in MPFI Mode
