Old 04-28-2008, 05:29 PM   #48
blizzardrunner
Member ID: 82584
Re: my crew cab dually build thread
well, right now im working on the fuel lines for it. Because it was fuel injected, and the engine came out of a suburban, i have the lines that go from the throttle body to the filter, which is located halfway back the frame. on a suburban they continue from that point back the frame to the tank which sits in the middle of the two framerails. On this, im making it single tank and the tanks are mounted on the side of the frame. So im in the process of bending lines over to the tank so i can actually run it by itself. Will get pics when done.
